Using AS to redefine a property in a dataview query
For example, imagine this:
TABLE WITHOUT ID NestedObject.name
FROM ""
WHERE file.name = this.file.name
Is there a way to use AS so as it can be written
TABLE WITHOUT ID N.property
FROM ""
....something that changes NestedObject to N
Tried the dataview documentation but not sure what to search for…name? alias? variable? those are taken by other things.
If NestedObject is not a list you can use FLATTEN NestedObject as N. If it’s a list the previous would actually flatten the list into each element of that list. If you would like to rename a list, e.g. MyList, to somthing else, you could try FLATTEN list(MyList) as M.
