In Editing mode, I want YAML list items (e.g., tags) to appear one per line, regardless of the note pane’s width.
At this width, tags render on a single line:
I’d like them to stack vertically always, one item per line:
I searched for similar requests but didn’t find a solution.
Question
Can a CSS snippet change the appearance of YAML front matter in Editing mode to force one-per-line list items? Any guidance is appreciated.
I found the solution to my own question. In case this is helpful to someone else, I’m sharing it
here.
Place the following in your obsidian/snippets folder:
* Properties → Multi-select pills
* One pill per row, left-aligned, content-width pills
/* Stack vertically, but don't use gap (we'll space pills via margins) */
.metadata-property .multi-select-container {
display: flex;
flex-direction: column;
align-items: flex-start; /* left align pills */
gap: 0;
/* Each pill hugs its content width */
.metadata-property .multi-select-pill {
display: inline-flex;
align-items: center;
max-width: 100%;
white-space: nowrap;
width: auto !important;
margin-bottom: 6px; /* spacing between rows */
/* Remove extra margin after the last pill (before the input row) */
.metadata-property .multi-select-container > .multi-select-pill:nth-last-child(2) {
margin-bottom: 0;
/* collapse by default */
.metadata-property .multi-select-input {
height: 0;
min-height: 0;
padding: 0;
margin: 0;
border: 0;
opacity: 0;
pointer-events: none;
/* expand ONLY when the input itself has focus */
.metadata-property .multi-select-input:focus {
height: var(--input-height, 28px);
padding: var(--size-2-2, 4px) var(--size-2-3, 6px);
border: initial;
opacity: 1;
pointer-events: auto;
system
Closed
4
