Hello!
I am an avid user of Obsidian for almost two years now, and I just simply love everything about the Desktop Application. It is perfect. But, as you guessed, I am not able to love the mobile version - or sync - as much. Why is that? Well, I don’t see how I should be able to jot down a quick note on mobile. The whole thing just feels clunky and the interface feels filigrane but also kind of swoogly. With sometimes loading times exceeding 10 seconds. And with sync I had some horrible happenings, which deleted half of my files.
My main point here is that I would like to ask you if there has been any concepts or ideas floating around, regarding mobile usability and working with sync. Because I surely am would be willing to pay for sync and use Obsidian properly on my phone. (Sorry to be an a*hole here, but notion…)
I would have a proposal of an idea, which involves just sending a table of all of your notes (kind of one json-file?), basically just the metadata. And then fetch notes on demand. This could also work not necessarily only over network. It could also work in a sense, that you fetch all the data over sync like normal - but then have a ressource-limited version, which only loads one note into memory when used, and otherwise just referring to the table of notes. (I don’t know about the inner workings of Obsidian, so I apologize if this sounds stupid).
If somebody of the team is willing/keen on throwing ideas around, I am up.
I share your frustrations, and am also a user of Sync. It just doesn’t work trivially from a UX standpoint. So my biggest frustration with mobile is indeed the wait time to open app (iPhone 14 Pro - 5000 notes - takes +/- 3-5 seconds - minimum of plug-ins) but even more so is the file-by-file sync that happens when the app is then open.
Why does the sync have to happen file-by-file (instead of batch sync’n (and conflict resolution) everything from the server to the device and vice versa)?
I also checked the roadmap now and am quite satisfied with what I read there. It seems to me that a quick capture feature is also what solves the problem on mobile to some extent (jotting down a quick note).
And I am also aknowledging the fact, that the team works hard on sync and that these hickups I talked about are not a recent phenomenon.
For now I am using Nextcloud on my own server to sync my notes, and Nextcloud notes to directly sync that into my vault. I will post, how exactly to do it, in show-and-tell.
