We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
When cutting and pasting some links from one file to another file in another directory, the relative paths in markdown style don’t update in time, although the link still work.
when pasting, detect the content and find internal links to files and images. Then update the relative paths.
rename the linked file or image with an addition and then rename them again with the origin name, using the always update internel link
function. I think there are some utilities available for reusing.
nothing
