Unwanted blank added when pasting code into code block
  1. copy python code from other place.
  2. paste the code into a code block.
The procedure will inserting another blank line between any two original code. An example I just pasted a minute ago.
class Solution:
    def sortedArrayToBST(self, nums: List[int]) -> TreeNode:
        def helper(left, right):
            if left > right:
                return None
            # 总是选择中间位置左边的数字作为根节点
            mid = (left + right) // 2
            root = TreeNode()
            root.left = helper(left, mid - 1)
            root.right = helper(mid + 1, right)
            root.val = nums[mid]
            return root
        return helper(0, len(nums) - 1)
It shoud not insert extra spaces. Just like this:
class Solution:
            if left > right:
                return None
            root = TreeNode()
            return root
  • Windows 11, Obisidian 0.15.8
Yes, this is pretty irritating, isn’t it? I think this has been brought up before, and what you need to do is ‘paste without formatting’ (Ctrl+shift+v on Windows IIRC). I need to remember that more often myself.
