- Attempt to connect to a remote vault using Sync
- When prompted for the encryption password, enter an invalid password
The expected result would be a dialog window or other warning informing the user the vault key is invalid.
The dialog window is generated, but only appears extremely briefly. For the most part, the user just sees the underlying dialog with the animation of a square not feeling so good. (I had to use a screen recorder to even grab the content of the dialog window by playing it back at extremely reduced speed).
This occurs on both mobile (Android 13) and desktop (Windows 11).
- Operating system: Android 11
Debug info:
Operating system: android 13 (Google Pixel 7 Pro)
Obsidian version: 1.4.0 (80)
API version: v1.0.0
Catalyst license: none
Legacy editor: off
Restricted mode: on -
Operating system: Windows 11
Debug info:
Obsidian version: v1.0.0
Installer version: v0.15.9
Operating system: Windows 10 Pro 10.0.22623
Legacy editor: off
I am not sure why Obsidian displays my OS as Windows 10; perhaps it’s derived from some field based on the licence type.
Screenshot of the dialog window which appears extremely briefly
