Unsolved, urgent bug: remotely using the save plug-in on IOS to use http+ip+ port + path through webdav fails. This problem is caused by a few errors in the API interface of obsidian software, not remotely. Because remotely save’s plugin authors wrote a message on github explaining the bug. In addition, I need to explain that I have no problem with this problem on the windwos version and can synchronize normally, but I failed to perform the same setting steps on the ios side. I have browsed the Chinese forum of obsidian, which also shows that the problem is caused by the obsidian software itself, see the following figure for details
The bug here is not solved but bypassed (by using https domain name instead of http), so far the http+ip+ port method can not achieve webdav synchronization on the ios side of obsidian software
It would help if you linked to the bug and message that you mentioned.
The great moderator(Mr. CawlinTeffid), this issue about third-party webdav protocol synchronization on the ios side of obsidian software is indeed a bug caused by obsidian software itself(This bug is not caused by the plugin), what can I do to let developers see this problem?
@CawlinTeffid Excuse my poor English, but I’m recasting the bug scenario: Use the obsidian software on an iphone to open a remotely save plug-in and use the webdav protocol to perform synchronization Settings. The webdav server URL set must be http, that is, the ip address and port number. In this case, bugs may occur that the webdav server cannot be connected. However, the URL is changed to https no problem, this bug does not produce errors on the windows side, and note synchronization can be achieved through http:ip and port, only the ios side has such a bug.
You report it to the plugin’s author on GitHub, and they can contact the Obsidian team if need be.
You said this:
Could you post here a link to that message?
Issues · remotely-save/remotely-save (github.com)
Well, it doesn’t seem like obsidian doesn’t want to fix the bug, it’s that ios doesn’t allow http connections
