Debug info:
Obsidian version: v0.14.2
Installer version: v0.14.2
Operating system: Darwin Kernel Version 21.4.0: Mon Feb 21 20:36:53 PST 2022; root:xnu-8020.101.4~2/RELEASE_ARM64_T8101 21.4.0
Legacy editor: on
Safe mode: off
Plugins installed: 1
Plugins enabled: 1
1: Advanced Tables
Does anyone have a solution to this issue yet? I’m having the same problem when exporting! It used to be fine but now all code exports turn out like that…
Unfortunately, installing an older version on the same system doesn’t seem to work, but I tried installing a way older version (12.19) on a new device, and it seemed to export to pdf in the right format.
The error might likely come from the version update?
I use a css snippet for code block, which I copied from a theme and slightly modified it, BlueTopaz? I think. And the results is that I don’t see this issue. Maybe this will also help you.
