I have a more or less medium sized library (1169 files, 127 folders).
However, today I saw, that the Backlinks panel doesn’t show all unlinked mentions. In comparison I did a search with the Search panel which shows a lot more results (see screenshot).
I have no alias set for the daily note, so Obsidian should just use the filename for the Backlinks panel.
Same result with third party plugins disabled.
The Backlinks panel shows the same results as the Search panel. Most of the results are values in the YAML frontmatter of the notes.
The Backlinks panel only shows one result where instead it should show a lot more.
- Operating system: macOS 12.1
- Obsidian version: v0.12.19 (Installer version: v0.12.3)
