Unique Obsidian URL that does not depend on note folder or note name
How can I get a unique Obsidian URL that doesn’t depend on some Note folder or Note name (for example, unique Note identifier like Zettel Id)? I need that because if I change a note folder or rename the note, my earlier get Obsidian URL will not work.
This is particularly important for Hook users.
there is a workaround for changing file name but not folder. you can let your notes have the Zettelkasten UID and then set aliases for that note. so next time you want to change the name of that note you just have to change the aliases. the link will remain intact since your real note name will still be the UID.
