The various context menus can get quite long and bothersome, especially with plugins. Despite only having four extra buttons from plugins, the file menu is so long it oft cuts off the very bottom “delete” button on my screen. Which is an issue as that is one of the most used buttons. But as all context menus share the same label, it is really hard to remove anything with css without breaking another context menu.
Give each context menu (file menu, more options, editor menu, folder menu, non-folder menu etc.) their own label, selector, or something. So you can target it specifically, without affecting all the other menus.
There is one plugin I know off which can remove items from the context menus and the redundant separators. But it currently appears to be broken. And the current css solution means affecting all context menus in the exact same way. Which means you have to compromise somewhere.
