Unify fold headers and callouts
If I need to keep a block of text collapsed, then I use a callout. If I need fast navigation, then I use headers.
I would like to have both.
Some of the headers are collapsed and some not.
Something like “-” in callouts.
[!quote]-
Possible solutions:
  • #- Folded header
  • #[!quote]- folder and callout at the same time
Does putting the header in the callout work for you?
> [!quote]- ### Header
Unfortunately no.
Here is the example of md file:
# Header1
# Header2
# Header3
Text here...
A lot of text here...
## Header3.1 workaround
Workaround header is visible in the table of context.
> [!quote]- ## Header3.1 + Callout
> Folded but is not in the table of context
Table of context:
  • Header1
  • Header2
  • Header3
    • Header 3.1 workaround
“Header3.1 + Callout” is not in the table of context.
