The unfold headings and lists command doesn’t work on frontmatter
- make sure frontmatter is visible
- Trigger the command
fold all headings and lists - Everything should be folded…
unfold all headings and lists
Result
Everything is unfolded as per the trigger of the unfold command, except the frontmatter
Desired Result
even the frontmatter should be unfolded
allow the unfolding command to work correctly on the frontmatter
