Undo in Bases only works haphazardly, and not at all for changes to the Base itself
  1. Create or open a base
  2. Edit some values of visible properties
  3. Undo them with the shortcut Ctrl+Z
  4. Observe how it sometimes does and does not undo
  1. Enable or disable a property
  2. Try and undo that change with Ctrl+Z
  3. Observe how it doesn’t disable or enable again
  1. Changes should reliably be undone, no matter how or what is selected in the Base
  2. Changes to the base should be undoable (should I open a feature request about this?)
  1. Depending on where the cursor is or what is selected, undo does or doesn’t work
  2. Undoing of Base changes doesn’t work
	Obsidian version: v1.10.6
	Installer version: v1.10.6
	Operating system: #1 SMP PREEMPT_DYNAMIC Fri, 02 Jan 2026 17:52:55 +0000 6.18.3-arch1-1
