Underbrace and overbrace not rendering properly
\underbrace{\nabla\times\mathbf{u}}_{\text{curl}} = \overbrace{\nabla\times\mathbf{u}}_{\text{curl}}
	Obsidian version: v1.1.16
	Installer version: v1.1.9
	Operating system: Windows 10 Home Single Language 10.0.19045
	Catalyst license: none
	Legacy editor: off
	Base theme: light
	Community theme: Minimal v6.2.3
	Snippets enabled: 1
	Plugins installed: 9
	Plugins enabled: 9
		1: Annotator v0.2.10
		2: Periodic Notes v0.0.17
		3: Dataview v0.5.55
		4: Natural Language Dates v0.6.1
		5: Excalidraw v1.8.22
		6: Quick Latex for Obsidian v2.6.1
		7: Tasks v3.1.0
		8: Advanced Slides v1.20.0
		9: Emoji Shortcodes v2.2.0
It seems to be related to how long the term is. For instance,
\underbrace{\frac{a}{b}}
\underbrace{\frac{a}{b}\frac{a}{b}\frac{a}{b}}
and
\underbrace{\frac{a}{b}\frac{a}{b}\frac{a}{b}\frac{a}{b}\frac{a}{b}\frac{a}{b}\frac{a}{b}}
This should be an easy fix because I think LaTeX usually adds dashes to make the braces match the size of the term.
The problem persists even if I turn off all community plugins and CSS snippets.
This is indeed an issue that occurs on windows with obsidian. See also:
A current workaround is to find the proper zoom level and or font size.
Hopefully one day this gets fixed by obsidian or mathjax.
Well, while I think that would be good to fix this for future versions, it shows up alright on an exported PDF. So this is less concerning for me than I was expecting.
