I have some custom properties and try to delete them on Android. I have one of date-time type and one of text type.
I open All properties view. Long tap on custom property. In pop-up I see “Unassign type”, but it’s greyed, i.e. unaccessible.
• After that I renamed properties, but Unassign was still greyed.
• Then I changed property type from date-time to text. “Unassign type” became normal (clickable), I tapped on it. And then property type automatically changed back to date-time. So property was still there.
Yes. I turned off all community plugins (restricted mode), snippets, theme.
I expected to delete custom properties.
Custom properties were not deleted.
Operating system: android 6.0 (HUAWEI H60-L04)
Obsidian version: 1.8.10 (197)
API version: v1.8.10
Base theme: light
I don’t think this is necessarily a bug … I could still be wrong though …
But on desktop, from what I can see, you can only “remove” (“unassign type”) the keys not being used anywhere in your vault (i.e.: where the count of results showing up next to a key in the All properties view/tab is 0)… which doesn’t seem to be the case for your key named changed2 (as it’s still actively used in 16 notes from your screenshot) …
Sidenote: Properties keys seemingly holding no value(s) doesn’t equate to not being used (as in this case, the value is actually null)
