I am trying to write some proof trees using bussproofs, however within the bussproofs enviroment I can’t seem to write in LaTeX. As an example, I can’t write
\begin{prooftree}
\AxiomC{\varphi}
\AxiomC{\psi}
\BinaryInfC{\varphi \wedge \psi}
\end{prooftree}
but it of course works fine if I write regular plaintext within the curly brackets.
I have searched documentation and forums but found very little in general. I believe it might be the case that you can’t actually write math expressions within the bussproofs enviroment (I really hope I am wrong) since normally you would have to surround the expression you want in there with $-signs, but this screws things up in obsidian.
