Repro
- create checklist preceded with a header eg.
test
- abc
- def
- efg
- abc
- def
- efg
- Move cursor to the last item of the list
- Press Up arrow several times - you should see the cursor being stuck at the last item.
I cannot reproduce. You have probably some community plugin causing the issue.
I can’t reproduce. I am going to close this thread. If you still have this problem please open a new bug report thread and make sure you follow the bug report template and the troubleshooting instructions.
