I have been unable to create a remote vault to sync. Things I have tried
Turned on Sync on Core Plug-in
- Created a local vault successfully
- Confirmed I was logged in with my account on the app and on the web.
I have tried for over an hour. What am I overlooking?
Just need to create a remote vault so I can sync it
Any ideas? I appreciate the help.
Jean
You have a subscription, right? Because the error seems to indicate you don’t.
If you do, are you logged in here? NOTE: obsidian.md and forum.obsidian.md IDs and passwords are separate; be sure you are using your obsidian.md one.
Ariehen, I appreciated the response, Yeah I have one.
That screen looks like the web. You need to be logged in within the Obsidian app (see my screenshot)
I would email support if that doesn’t work.
Thanks, I thought I was missing something. The service, IS free right?
What ariehen said. Here’s the subscription link: Obsidian Sync
There are other ways to sync, too, if you prefer (tho Obsidian Sync works very well and is end-to-end encrypted).
system
Closed
8
