UI issues when Obsidian window is (horizontally) small
Very long titles cause the third note UI elements (see image) to be cut off. Usually after trying to resize the windows.
Very large amounts of latex seem to do it as well:
Inverse of compound symmetric matrix.zip (480 Bytes)
  • Operating system: W10
  • Obsidian version: 0.7.3
I am sorry I not sure I get what your problem is.
What is cut off?
And whatever problem you have, please try the default CSS first.
Hi, I checked the default css same issue. Notice on the far right note, none of the pin close etc options are available
Thanks I managed to reproduce this problem.
I don’t think it has anything to do with latex and titile.
If you have two or three notes open and you shrink the obsidian window, at some point the UI will break and you’ll start loosing UI elements.
This is something to think about.
Idk if the in-page search function will be augmented soon enough, but just in case it wasn’t mentioned (maybe under some keyword I couldn’t think up) I can’t find the “close” button here for CTRL+F when I’m working with multiple views :
But when it is just a single view, the close button is there:
In the meanwhile, the good ole ESC button works nonetheless.
