UI font size is so small that it makes Obs unusable for me
All that is in the replies to the “too small UI font size” posts.
However, they are all about CSS that I don’t have time to learn.
Is there no plugin that can increase the UI font size without me having to deal with CSS?
I read somewhere that Obs 0.16.2 will finally resolve this. Is that true?
This works for me, You may want to give it a try.
This can be found under settings → appearance
Ctrl + Plus and Ctrl + Minus will increase and decrease the font size of both your note and the Obsidian UI.
That is changing only the font size of the content. I need to up the illegibly small font of the user interface, e.g. the menu on the left margin.
You may want to try this new setting in v1.0.0:
You could experiment with the Windows font settings, however doing so will change the font size for all programmes.
Did you try Ctrl Plus and Ctrl Minus, which changes the UI font (e.g. the menu on the left margin) ?
It changes the UI, too, at least in the default theme in Obsidian 1.0.0. I’m not sure how to adjust them separately.
