Two-way Obsidian-Zotero sync?
Here’s what I’m trying to do: I use the internal Zotero PDF reader to read PDFs and take notes. I highlight the PDF and then create one large Note in the righthand sidebar summarizing the article and my thoughts on it. I would like to (1) import those sidebar Notes with Obsidian, so that I can take advantage of the tags and search in Obsidian’s database; but then (2) also have the Obsidian version update with any changes that I make on the Zotero side and (ideally-I know this might be too much of a pipe dream) to have the Zotero note update with any changes that I make on the Obsidian side.
I have been able to do (1) using the Zotero Integration plugin, but I haven’t been able to achieve (2). Does anyone know if there is a way to do this using Zotero Integration? Or is there some other plugin I’m unaware of that can do this? (I also tried Obsidian-Zotero from AidenLX but I’ve been asking in the forums and I’m pretty sure this won’t achieve either (1) or (2).)
Any help greatly appreciated!
This one possibly. Never got around to trying it.
