hqgu
1
I have two questions in the Editing mode:
- It seems that the shortcut ctrl+c doesn’t work. Every time I have to use Right-click and select the copy button.
- Every time when I switch from reading mode to editing mode, I have to press the “Insert” button before I can do my editing.
Does anyone have the same problem? How to fix?
JimK
2
Hi @hqgu
Do you maybe have VIM mode enabled?
Settings | Editor | Vim Key bindings
I never used it in Obsidian but I remember from a long way back that it does copy/past (and a lot of other things) differently.
If that isn’t it can you open the “Help” vault
Open another Vault icon | Obsidian Help
or a sandbox vault
Open another Vault icon | Get Help “Help” button | Sandbox Vault “Open” button
and see if you have the same issues in that vault?
hqgu
3
Thank you for your wise advice. It seems that you have the right answer.
