I have tried searching for “<>” or “XML tags” or “HTML tags” but don’t find an answer to how Obsidian behaves when using custom tags inside < > brackets. I for example use it for things like < definition > xyz < /definition > and it highlights the keywords in purple, but what does it mean??
I would use it e.g. to specify the link type like so: < semantic relationship > [[linked file]]
But that’s just an example.
I am guessing Obsidian is interpreting whatever you put between angle brackets as HTML.
Iirc, Markdown is supposed to include any HTML in a document. So you can old something with <strong>text</strong> just as well as **text**.
If I’m right, then anything that is valid HTML — including <definition> ... </definition> — will style something in your note. Anything that isn’t recognized as HTML should probably be ignored.
CommonMark, as far as I know what Obsidian uses, also defines < and > to put links in, which is almost always better than to rely on implicit linking.
Example: <https://forum.obsidian.md/t/trying-to-understand-what-means-does/18983/3>
