KrKAlex
December 15, 2022, 10:06am
1
Hi everyone,
I tried to write an equation for the first time in Obsidian, that contains multiple letters in the subscript. I looked on the internet what I could find, using the {} but now I have a problem it does not include the whole equation anymore.
How could I fix that? If I remove the {}, then there is only the first letter subscripted.
Many thanks!
@KrKAlex What is the actual source text of your equation? Please include the source text here as pre-formatted text (wrapped in three backtics ```).
P.S. I think, the percent sign causes the problem. It is used in LaTeX as comment delimiter, and should be escaped here using a backslash: \%.
KrKAlex
December 15, 2022, 5:53pm
3
Hi @saf-dmitry ,
As pre-formatted text: FCcible = [(FCmax – FCrepos) × % VMAdésiré] + FCrepos
However, in the pre-formatted text and on the screenshot, the subscripts are not subscripted, they are just in lowercase …
I am not sure where should I add the backslash? Instead of the closing dollar sign?
Many thanks!
holroy
December 15, 2022, 6:19pm
4
It does indeed seem like you should escape the percentage sign, as it comments out the rest of the equation. See image below for the difference:
So you need to add the backslash in front of the percentage sign.
@KrKAlex
You should add the backslash in front of the percent sign: \%:
$FC_{cible} = [(FC_{max} – FC_{repos}) \times \%VMA_{désiré}] + FC_{repos}$
P.S. Actually, the correct way to write text indices would be
$FC_{\text{cible}} = [(FC_{\text{max}} – FC_{\text{repos}}) \times \%VMA_{\text{désiré}}] + FC_{\text{repos}}$
KrKAlex
December 16, 2022, 8:18am
6
Thank you @saf-dmitry and @holroy , it works!
system
Closed
December 23, 2022, 8:19am
7
