Travel Workflow and Template with map built-in
Hey! I wanted to share a use case that accounts for roughly 50% of the motivation behind building Agate plugin.
I love traveling, wandering around for weeks or months at a time, and experiencing different places (mostly backcountry). For some sentimental reason, I really enjoy both planning and executing these trips, and then creating some kind of artifact to document each journey. Now that I have a family, having personal maps is also a nice addition to our family travel photobooks.
So, what you’re looking at:
  • A Travel template: A note for each trip, containing dates, budget, itinerary, and other basic details. Nothing too fancy.
  • Three Bases: Places (POIs), Locations (cities, towns, etc.), and Experiences (e.g. whale watching or snorkeling). Experiences are the highlights of the map.
  • A map powered by Agate: The map itself is defined by a static JSON spec. Agate pulls the relevant data directly from the notes — for example, all Experiences and Locations linked to the current Travel note.
  • Routes and experience locations: These are stored in separate files, organized by trip. I’m not particularly concerned with precise routes or exact coordinates for every experience, so I use AI to generate an initial version and then iterate on it.
  • Basemap: I’m using the MapTiler API. It has a free tier, but some of the baked-in labels can get in the way. I’m still exploring alternatives (Mapbox is one possibility).
The same underlying data — literally the same Bases — is also rendered below the map using a different spec, this time highlighting budget, time, locations, and experiences.
I also added a small custom CSS snippet to support icons for Experiences.
Obviously, the result is quite opinionated. I tried to strike a balance between making the setup reusable across different trips while still leaving room for trip-specific details.
Visually, I wanted it to feel like a natural extension of Obsidian, rather than a separate dashboard. It should be fairly straightforward to customize, or even adapt to the active theme (e.g. swap colors when the theme changes).
One more example: this is a demo included with the plugin (meaning I haven’t actually done this hike yet, although I plan to!). It’s another exercise around the same idea, but focused on backcountry hiking, with temperature, altitude, and precipitation charts overlaid on the route.
Happy to share the CSS snippets and specs if anyone is interested. Hope you find it useful!
PS. I know there are plenty of plugins doing maps, charts, timelines, and tabels out there. Few of them are fantastic and wonderful.
So, why Agate is a good fit here, and why I thought this is worth a publication? Because it is one solution, that
  • does not insist on specific structure outside of Obsidian (and bases, but it can work without bases too)
  • does not insist on specific design choice or choice of visuals. For example, here map can be interactive (pan, zoom), but I deliberately set it to be not; It can use any* background source. result can be network, barchart, beechart, or anything in between -or even a combination of those, in one.
  • it works with many plugins, where data is native to obsidian or close (Habit21 is a fantastic plugin I use, it stores data as json objects, and Agate picks them easily).
  • in many cases (like here), result is an absract “spec” (template), separated from the data. So each travel (in this case) or each specifc note will show unique information, while reusing the same structure. keeps code DRY!
