Transparent text in exported pdf when using dark system color scheme
  1. Use Gnome DE and choose Style->Dark under appearance settings.
  2. Go to Settings->Appearance->Base color scheme and set it to “Adapt to system”.
  3. For the “Start here” document first shown when opening the sandbox vault, choose “Export to pdf”.
  4. Choose default options, save anywhere.
  5. Open pdf.
Y
Non-transparent text in the generated pdf.
The text is transparent, i.e white on white background.
Obsidian version: v1.4.12
Installer version: v1.3.5
Operating system: #1 SMP PREEMPT_DYNAMIC Thu Sep 7 00:25:01 UTC 2023 6.4.15-200.fc38.x86_64
Catalyst license: none
Legacy editor: off
The problem only appears when the theme is “adapt to system theme” and my system theme is dark (on GNOME, Fedora 38). If I pick the dark theme in Obsidian, the issue disappears.
There was a similar issue named " How to set basic black text on white background colors for PDF export when using a dark theme?" [How to set basic black text on white background colors for PDF export when using a dark theme?] but that was for the manual dark theme (which works in my case). Not sure if this is expected behaviour, if so, let me know.
