Transparent panel on iPhone
When I click the “FILES” dropdown menu, it opens the panel with the other options, but as you can see, its transparent, making it hard to read and navigate.
I’m on version 1.14.5, on iOS 15.8.8
Just to be sure :blush: : Are you using or did you try using Obsidian’s default theme (and/or disabling potential CSS snippets/plugins) ? :thinking:
I’m on a different version of iOS but looking at Obsidian on my phone and using the default dark theme, the colors in your screenshot seems a bit off (more on the blue side of things compared to the grey of Obsidian’s default theme) :woman_shrugging:
Moved to help section for not following the BR template.
