Transclusion of images external to vault fails in callouts
  1. Transclude a picture from outside the vault using the absolute path reference, placed within angled brackets, like so:
![pic](<C:/mypic.jpg>)
  1. This should successfully transclude the image. Once that is done, put the transclusion within a callout, like so:
>[!info]
The translusion should be unsuccessful.
Other formats appear to work just fine, for example
>[!info]
>![pic](file:///C:%5Cmypic.jpg)
An image should be transcluded within a callout
Instead, a “missing image” placeholder is rendered
Obsidian version: v1.9.14
Installer version: v1.8.4
Plugins installed: 24
Plugins enabled: 0
This is not a bug because we do not support this format for external images.
