Tracking time in projects and tasks with tags
Hi everyone,
I would like to track the time spent on specific tasks across different projects and then create an overview using Dataview, grouped and summed by project and task.
@holroy has already shared an excellent solution here:
However, instead of describing projects using inline fields like
[project:: Something] (timespent:: 0.5h),
I would prefer to use tags. I expect this to scale better, as tag functionality (including auto-completion and reuse of existing tags) becomes especially useful once tracking grows and the number of categories increases.
Example
I have two projects, “Something” and “Different”, each containing multiple tasks to be tracked, for example:
#projectSomething/task1:: 5 min
#projectSomething/task1:: 2 min
#projectSomething/task2:: 15 min
#projectDifferent/task1:: 222 min
#projectDifferent/task2:: 55 min
Desired Dataview output
I would like to generate a Dataview table with somehow like the following structure:
Project Timespent
total projectSomething 22 min
total projectSomething/task1 7 min
total projectSomething/task2 15 min
projectSomething/task1 5 min
projectSomething/task1 2 min
total projectDifferent 277 min
total projectDifferent/task1 222 min
total projectDifferent/task2 55 min
Optional: comments column
Ideally, I would also like to add a second column called “comments”, for example by writing:
#projectSomething/task1:: 5 min, blabla
#projectSomething/task1:: 2 min, xyz
#projectSomething/task2:: 15 min, hahaha
#projectDifferent/task1:: 222 min, yes
#projectDifferent/task2:: 55 min, no
Which would result in a table like this:
Project Timespent Comments
projectSomething/task1 5 min blabla
projectSomething/task1 2 min xyz
projectSomething/task2 15 min hahaha
projectDifferent/task1 222 min yes
projectDifferent/task2 55 min no
Could you please help me with this?
Also, does using tags instead of inline fields make sense for this kind of time-tracking setup?
Thanks a lot for your help!
Hi @Charly_Hermel21,
no, I did not consider a recursive Dataview query yet - could you please explain or give me an example for that?
