Touchpad gestures not working in Obsidian android
On OnePlus Pad with magnetic keyboard touchpad after update to Android 15.
Did you follow the troubleshooting guide
  • Restricted mode
  • No snippets
  • No plugins
  • Default theme
  • Blank vault
On OnePlus Pad keyboard touchpad should work with standard touch gestures, like long press to open file context menu, swipe right to open File menu, two fingers to scroll. On OnePlus Pad touchpad, there is no scroll button, neither left or right click.
When using touchpad Obsidian behaves like if it’s mouse. No swiping gestures, long press not working (only for dragging files), neither using two fingers to scroll in document (only by dragging scrollbar). When using touch screen, everything works as expepected. In other apps there is no problem.
  • Operating system: android 15 (OnePlus OPD2203)
  • Obsidian version: 1.8.7 (191)
  • API version: v1.8.7
  • Login status: not logged in
  • Language: en
  • Live preview: on
  • Base theme: adapt to system
  • Community theme: none
  • Snippets enabled: 0
  • Restricted mode: on
It would be nice to add option to force usage of standard Android touch gestures instead of making touchpad behave like a mouse.
