Toggle comment
  1. Toggle comment on a line with some text with Ctrl + /
Changes:
<some text>
Into:
%% <some text %%
  1. Without doing anything else, toggle comment again with Ctrl + /
Y
<some text>
<some text>
Note: There is a space character before and after the text.
Obsidian version: v1.8.10
Installer version: v1.5.12
Operating system: Windows 10 Pro 10.0.26100
None.
I am not sure I understand your repro steps.
However, you have to be careful writing <some text> because this is interpreted as an html tag.
You should escape it \<some text\>
I can reproduce and I agree that comment untoggle should remove the extra spaces to produce equivalent effect with ⌘Z.
Screenshots with Control Characters community plugin:
(text is selected by default but you can but cursor anywhere between double percent signs)
The <some text> was just a placeholder for any text. The <> are not part of the mandatory steps to reproduce.
@blue_emperor thanks for clarifying with screenshots.
I have no rights to edit the original post to fix the steps to reproduce.
