- Open any note in Live Preview mode (also reproducible in Source Mode).
- Type some plain text, e.g.:
Hello world - Select the text
Hello world. - Press Cmd+B (macOS) / Ctrl+B (Windows/Linux) — the text becomes bold (
**Hello world**). - With the bold text still selected (or cursor inside it), press Cmd+B / Ctrl+B again.
- Expected: The bold formatting is removed, returning to plain
Hello world. - Actual: The bold formatting is not removed. The text stays bold, or additional
**markers are inserted around the selection.
The same issue occurs with Toggle Italic (Cmd+I / Ctrl+I).
Y
- Tested in the Sandbox Vault (Help → Sandbox Vault) — issue persists.
- Restricted mode enabled (all community plugins disabled) — issue persists.
- Default theme — issue persists.
- Running the latest version of Obsidian (see debug info below).
The “Toggle Bold” and “Toggle Italic” commands should toggle — i.e., applying the shortcut to already-formatted text should remove the formatting markers (** or *), returning the text to plain.
This is the standard behavior in virtually every rich-text and markdown editor (VS Code, Google Docs, Notion, Typora, etc.) and was working in previous Obsidian versions.
The shortcut only applies bold/italic but never removes it. Pressing the shortcut on already-bolded/italicized text either:
- Does nothing, or
- Wraps additional
**/*markers around the already-formatted text (double-bolding).
This makes the commands non-idempotent and no longer function as toggles.
Obsidian version: 1.13.1
Installer version: 1.12.7
Operating system: Darwin Kernel Version 27.0.0: Wed May 27 02:27:52 PDT 2026; root:xnu-13361.0.0.501.1~2/RELEASE_ARM64_T6000 27.0.0
Catalyst license: vip
Insider build toggle: on
