Tiny behaviour tweak: Middle mice click on links should open in background
Hi, small tweak, the standard behaviour for middle mouse click in most software is to open the link in a new tab in the background, not open and switch the view to it. Hopefully this can be adjusted to standardise the user interface behaviour as much as possible. Thanks in advance!
Middle mouse click also switches the view to the newly created tab
Don’t switch the view to the newly created tab when middle mouse clicking
This seems like a Feature requests topic.
Could you have a search when you get a chance, and if you don’t find anything, create a topic following the template. Thanks!
done!
Check out the setting Editor > Always focus new tabs. If you disable this, the tabs should open in the background.
Yep that did it, thank you for the solution, don’t know how I missed that!
