Three dashes produce horizontal rule even inside checklists and block quotes
Type the following (without the code block) anywhere:
- [ ] foo
- [ ] bar
> foo
> bar
I tried it in Sandbox vault.
Horizontal rule is not rendered, neither in edit mode nor in view mode.
According to Markdown guide (/basic-syntax/#horizontal-rules) and at the time of writing latest commonmark spec (/0.31.2/#thematic-break) a horizontal rule should be rendered only when ---, ___, or *** are on a line “by themselves”. To my understanding, since there is - [ ] and > respectively, this should not result in a rule.
Both in edit mode and in read mode horizontal rule is rendered cutting the checklist or block quote in half. Interestingly, checklist is affected in reading mode while block quote in edit mode for Sandbox vault.
Obsidian version: v1.8.7
Installer version: v1.8.7
Operating system: Darwin Kernel Version 24.3.0: Thu Jan 2 20:24:16 PST 2025; root:xnu-11215.81.4~3/RELEASE_ARM64_T6000 24.3.0
Catalyst license: none
Wanted to include links to markdown guide and commonmark specification but the system won’t let me, added relevant section at least…
I don’t think this is correct either.
The two cases you report do present bugs but they are different bugs and also different for LP and reading mode. So I am going to close this BR.
