The documentation says
Front matter is a YAML block with triple dashes both before and after. It also needs to be placed at the very top of the file.
But if I write tags at the beginning, they don’t work (Example from the forum).
tags:
  - #Uni/Assessment
  - #Uni
But if I insert text in front of this block, the tags will appear in the list.
aaaa
tags:
  - #Uni/Assessment
  - #Uni
A very strange contradiction. How to do it right?
you will have to put the tags inside quotes. for example- “#tag1” or ‘#tag1’.
Although I am not 100% sure but I don’t think that it is a bug. It is just that YAML works like this
But if I put quotation marks then the # prompt doesn’t work. Another bug.
"#(no tips)
I’m talking about that.
I tried doing the above and yes there are no prompts while trying to add tags in the metadata. However it is also the same inside the body. So i guess it is less of a bug and has got more to do with syntax.
Just don’t use # in the YAML—it means comment starts here.
These should both work:
tags: [Uni/Assessment, Uni]
# Rest of the note
or
tags:
  - Uni/Assessment
  - Uni
# Rest of the note
Ok, I’m using tags a lot and I’m looking for a way to type them quickly. If I do not use #, I can very easily make mistakes when typing.
For example, in TiddlyWiki I can quickly select ready-made tags and not have to worry about remembering their names every time.
Therefore, I am waiting for the system to allow me to do this, instead of constantly typing with my own hands.
It probably won’t. YAML is what YAML is.
