Hello the “n” key does not work when I use “shift” to capitalize for 2-3 weeks. How to solve this problem?
Is the “n” key and shift fine in other programs?
I’d follow the debugging steps to try to get to the bottom of it:
+1 for going through the debug steps. But also, what keyboard layout or language region is your keyboard set to?
Maybe you’ve just accidentally bound a hotkey to Forget what I said. Obsidian will not let you bind a hotkey like that.Shift+N or a Plugin did. Take a look in Settings -> Hotkeys
I don’t believe it’s possible to bind shift+[key]. But it is definitely worth double checking. (Edit: missed your edit, haha)
Yeah, I already checked. My mistake.
