The Commonplace Garden: a method for those who collect and think in the same gesture
I have always kept notebooks. Physical, digital, scattered files. Everything ended up in them: quotes from books, reading notes, immediate reactions, reflections that started from someone else’s idea and ended up somewhere unexpected. I have never kept a pure collection of other people’s material, and I have never kept a journal of my own thoughts alone. The two things, for me, blend in the very moment I write.
When I tried to adopt the Zettelkasten, it derailed more than once. The atomization of notes (one concept per note, everything linked) did not match the way I think. Breaking apart a page where a quote, a comment, and the sketch of an idea naturally coexist cost me effort without giving anything back. Mandatory links multiplied nodes without producing clarity. Maintaining the system became an activity separate from writing, and at some point it weighed more than the writing itself.
It was not a matter of discipline. It was a matter of form: the tool did not match the gesture.
In the end I built something different. I call it the Commonplace Garden: from the commonplace book of the Anglo-Saxon tradition, and from the metaphor of a garden, because the classification I use is botanical. It is implemented in Obsidian, but it would work on any editor based on local files.
Why the Zettelkasten and Digital Gardens fail for an HSP
If you are a Highly Sensitive Person, you probably recognize the pattern. Your natural way of processing is deep, branching, holistic. You absorb a lot, you connect a lot, and the boundary between collected material and your own thought is porous. This is precisely what makes the most popular note-taking methods problematic.
Atomization is the first problem. The Zettelkasten demands that each note contain a single concept. But a mind that processes in depth produces intertwined thoughts: a quote triggers a memory, the memory generates an analogy, the analogy opens a question. Breaking this flow into separate fragments is not organization, it is mutilation. It generates cognitive friction, and for someone already sensitive to overload, that friction carries a disproportionate cost.
Maintenance is the second. Tags, codes, dashboards, periodic reviews, the implicit pressure to link everything to everything. For a nervous system that already absorbs many stimuli from the environment, this digital bureaucracy is not neutral: it is an additional load that drains energy away from writing and thinking. The system should serve the work, not become work itself.
The third is subtler: the anxiety of the perfect system. Structured Digital Gardens and the Zettelkasten have an aesthetic and formal component that, for those prone to self-criticism, easily turns into yet another place to feel inadequate. The note is not atomic enough, the links are not complete enough, the system is not tidy enough. The spontaneity of writing shuts down.
The Commonplace Garden is a response to these three traps. It is an opportunistic repository, tolerant of disorder, where organization emerges from use and requires no dedicated energy.
The method step by step
Two folders, nothing else
The vault has only two folders.
repository/ holds all living thought. Notes, quotes with commentary, autonomous reflections, ongoing syntheses, elaborations at any stage. Notes take whatever form and length they take: one line, three pages, a quote followed by two paragraphs of reaction. They are not broken into atomic units.
archive/ holds finished products. A published essay, a delivered chapter, a post that went out. Closed material that no longer changes.
Free notes, not atomic ones
You write the note the way it comes. If a reading session produces three intertwined paragraphs with personal commentary, they stay together. The system follows the rhythm of thought, it does not constrain it.
The botanical classification
Each note carries a type: field in its frontmatter. It describes the nature of the note at the time of writing, not its destiny.
type: graft
source: "Ursula K. Le Guin, The Left Hand of Darkness"
seed – collected material with no elaboration: a quote, a fact, a reading note.
graft – someone else’s material alongside your own comments, annotations, reactions. For those who collect and think in the same gesture, this is the most natural type of note.
sprout – your own elaboration in progress, from external or internal prompts.
fruit – a mature, autonomous synthesis that stands on its own.
These are not mandatory stages. A seed can remain a seed forever. A sprout can emerge from nothing. This is not a workflow, it is a description.
Where relevant, the source: field indicates provenance. If the note is entirely your own elaboration, the field is omitted.
Spontaneous links, never mandatory
When you write a note and a connection to another one comes to mind, you place the link. When nothing comes to mind, you do not. No debt.
The graph grows passively as a byproduct of writing. It is not the center of the system. You do not curate it, complete it, or administer it.
Descriptive titles
The title is the first tool for finding things. It should say what the note is about in your own natural language, so that scanning a list of titles is enough to recognize the content without opening the file.
Fruits, being mature syntheses, can carry stronger and more general titles. A fruit titled “Secular ethics of doubt” stands out from a seed titled “Note on MacIntyre, After Virtue ch. 3” without any filter.
Reactive index pages
When you realize, while working, that you have several notes on the same theme, you create a note that gathers them: “Ideas on X”, with links to the existing notes inside. It is secondary writing, not maintenance. It comes from need, not from obligation.
Five channels to find things
  1. Full-text search – for when you know what you are looking for.
  2. Scanning titles – for rediscovering what you had forgotten you had.
  3. Index pages – for seeing existing notes on a theme side by side.
  4. Passive graph – for unintentional connections, consulted occasionally.
  5. Random note – for surfacing material buried by accumulation.
The fifth channel is the most important in the long run. Obsidian includes the “Random note” core plugin: one button, one random note. When you open the vault with no specific purpose, pressing that button two or three times is like flipping a physical notebook to a random page. It brings forgotten things to the surface without requiring the right words to search for them.
Zero dedicated maintenance
You do not schedule sessions to tidy up. You do not periodically review the repository. You do not catalog. If a note is never retrieved, that is fine. The repository is a notebook, not a database.
Why it works for an HSP
The Commonplace Garden is not just an organizational choice. For a Highly Sensitive Person, it addresses specific needs that more structured methods ignore or worsen.
It respects energy boundaries
When you classify a piece of information as a seed, you are drawing a boundary. You are saying: this is something I encountered, I have put it here, I do not need to carry it right now. For those who tend to absorb everything, this minimal gesture of deposit and release is a concrete form of regulation. It allows you to consume information without being consumed by it.
It lowers the load on the nervous system
Knowing that there is no maintenance to perform, that no note needs to be completed or linked, that disorder is accepted by the system itself, removes a constant source of pressure. The repository is a safe discharge space, not a second source of anxiety.
It supports deep processing
Without having to split thoughts into atomic units, you can allow yourself the luxury of extended elaboration. The passage from seed to graft to sprout to fruit, when it happens, happens at the pace of the mind, not at the pace of the system. Seeing a sprout become a fruit is confirmation that deep processing produces results, even when it does not produce speed.
It accepts porosity as a resource
Treating other people’s material and your own thought as a continuum is not a flaw in method: it is an acknowledgment of how a mind that absorbs, reacts, and re-elaborates fluidly actually works. The graft, as a note type, formalizes exactly this: you are not just a collector, not just a producer, you are both in the same gesture.
The underlying principle
This method is not without structure. It has an opportunistic structure: the structure is not built beforehand and is not maintained as a dedicated activity, but emerges from the gestures of writing and working. A link appears when it comes to mind, an index page appears when it is needed, a fruit becomes a strong node because of how it is written, not because of how it is classified.
Organization is a byproduct of use, not a prerequisite.
If your natural way of taking notes is already a hybrid of collecting and thinking, the Commonplace Garden does not ask you to change. It only asks you to name what you already do, and to stop feeling inadequate because you did not fit someone else’s method.
I’m not an HSP, but I have a vexed relationship to systemising. I like the orderliness and promise inherent in systems, but am congenitally disinclined to maintain one. It’s taken me a while to recognise this. I’ve been steadily discarding an overly systemic approach towards a process that fulfils your neat aphorism: “Organization is a byproduct of use, not a prerequisite”. I may borrow some of your ideas …
PS. I have two Obsidian vaults, one for banking other people’s ideas and phrases, and my own; one for managing my work projects. The comments above apply to the former; for the work projects I’m a heavy user of Bases. That’s the genius of Obsidian - you choose the level of systemisation you need, depending on what you need to pull back out of it.
PSS. I feel that this post on “permanently needing” objects can also be applied to overly-complicated note management sytems.
PSSS. I grew up on the land, and have agricultural classifications for my three top-level folders: Rickle (northern English for an untidy stack); Stooks (cut hay straw gathered and tied); and Gleanings (the grain).
That sounds great. To be honest, thinking about how to categorize and organize my notes before I even start writing or reading is a real drag. It adds a lot of friction to the process and turns something enjoyable into a chore. Sometimes, if I can’t figure out which category to put what I’m about to write in, I just can’t bring myself to start writing. So thanks for sharing.
I’d love to respond to the ideas here, but the fact that they were crafted by AI is really killing the vibe. The tells are everywhere!
Pretty sure I’m not HSP, just ADHD, but your structure/system appeals. I do have the tendency to get very wrapped up in the ‘setting up’ phase, and maintenance, etc., but I have yet to successfully keep any sort of system (Zettelkasten, Commonplace Book, Bullet Journal, Interstitial Journal, etc.) for any length of time. Complete lack of consistency. So obviously my brain is resisting most of the things I have tried. This leaves one with a sense of having been inspired and informed in the past only to have said inspiration and information fade away, never to be seen again. It is disheartening and dispiriting!
Any way, all that just to say that I am attempting to move back into an analog/digital hybrid system for notes and thoughts and a Commonplace Garden sounds like a great place to start. Thanks!
Really resonated with this line: “Organization is a byproduct of use, not a prerequisite.”
I’ve been trying something with a very similar spirit (Beyond). It also stays out of the way of the collect + think flow.
The only difference is it lightly separates excerpts and your own words, so you can see at a glance whether you’re mostly collecting or actually responding.
No atomization, no forced links — things just build up into your own thinking over time.
Feels very much like the same direction
I start reading but then I sniff AI - the zinger sentences, the paragraph breaks, the emdashes. I’m out.
I’m not opposed to AI usage but using it to write is offensive. Writing isn’t hard. Especially for Obsidian users.
I’m surprisingly unbothered by the AI writing because this was helpful.
