Open a Sandbox vault and paste the following in a file:
> [!info]+ asdfasdf asdfasdf asdfasdf
> > [!tip] asdfasdfas asdf asdf asdf asdf asdf asdf asd fas
> > * **asdfasdf**, asdfasdfasdf.
> > * **asdfasdf** asdfasd fasdfasdf asdf asdfasd ffasf.
> > [!tip] asdfasdf asdf asdfasdf as dasdf asdf as
> > * **asdfasdf** asdfsd fadfaasdf a;slkdj ffas a;lsdjkf asdf, e.g., asdfasdf.
> > * **asdfasdf** asdfasdfasdf a;sdlkfj a;lsdkj f;jdfsad
> > * fasd;flkjasd;fjkl as;ldfkj as;ldjf
> > [!tip] asdfasdf asdfadsf asdf asd fasdfs
> > asdfasdf asd fasd fasd fasd fasd fasdf as;dlfk j;aslkd jf;aslkdfj klajsd;lfkjasd;lfk jas;dlkfj as;ldkfj as;lkdjf; alskdj f;laksj df;lakjsdf ;laksjdf;lkjasd;fl k jasd;lfk jas;dlkfj as;ldkjf a;slkjdf ;laskjdf ;laskjd ;flk.; laks;lajksd f.
> > > [!abstract] fasdf a fads f.
> > [!tip] alsk;dj f;alkjs df;laksjd f;laksjd f;lasjkdf
> > a;sldkj fa;lskdj f;alskj df;alskdj f;asdjf ;alskdj f;alksdjf ;alsdkjf alsd;lfkjas d;flkj asd;lfkjas;dlfj. asd $\to$ jkl $\to$ dfgh.
No text rendering bugs/artifacts.
Weird artifacts. Disappear when that block of text is selected. Appear again when that block of text moves (due to scrolling, zooming, typing, etc.).
Operating system:
Fedora Linux 37 (Workstation Edition). GNOME 43.3. Wayland. Linux 6.2.7-200.fc37.x86_64. -
Debug info:
Obsidian version: v1.1.16
Installer version: v1.1.16
Operating system: #1 SMP PREEMPT_DYNAMIC Fri Mar 17 16:16:00 UTC 2023 6.2.7-200.fc37.x86_64
Catalyst license: none
Legacy editor: off
Snippets enabled: 2
Plugins installed: 4
Plugins enabled: 4
1: Vimrc Support v0.9.0
2: Calendar v1.5.10
3: Shell commands v0.18.1
4: Excalidraw v1.8.14
- I use 125% scaling (Wayland) on a 2560x1440 screen. The laptop has an NVIDIA RTX 3060 with a multiplexer. Obsidian probably runs on the Alder Lake iGPU (at least
nvidia-smi
says so). - Obsidian was installed using Flatpak and the
OBSIDIAN_USE_WAYLAND=1
variable was exported to the application using Flatseal. - The artifacts do not appear outside nested callouts (that’s why I discovered them so late!).
