I am simply trying to type text into a Kanban box or into a Canvas node. In both instances the text is being input in a vertical format. When the focus goes of the Kanban card or the Canvas node, it displays horizontally as it should.
- Updated Obisidian
- Updated all plugins
- Turned many questionable plugins off
- Turned Canvas off to see if it was core plugin related
- Turned Kanban off and tested in Canvas
- Changed from Prism to Default theme
- Turned off all CSS
- vertical text
- also detailed explanation and screenshots in Perplexity
