Templater Sudden Fail - Invalid reference date format
I created this template for my weekly notes and started bulk creating them for this year. The template worked just fine for weeks 1-12 and then suddenly started giving me the “invalid reference date format” error on week 13 and on.
My weekly notes are formatted to be titled like: 2025-W02
# <% tp.date.weekday("[Week] WW - YYYY", 0, tp.file.title, "YYYY-[W]WW") %>
[[The Library|❖]] **• [[<% tp.date.weekday("YYYY-[W]WW", -7, tp.file.title, "YYYY-[W]WW") %>|«]] • [[<% tp.date.weekday("YYYY-[W]WW", 7, tp.file.title, "YYYY-[W]WW") %>|»]] • [[<%tp.date.weekday("YYYY-MM", 0, tp.file.title, "YYYY-[W]WW")%>|M<%tp.date.weekday("MM", 0, tp.file.title, "YYYY-[W]WW")%>]] • [[<%tp.date.now("YYYY-[Q]Q", 0, tp.file.title, "YYYY-MM-DD")%>|Q<%tp.date.now("Q", 0, tp.file.title, "YYYY-MM-DD")%>]] • [[<%tp.date.now("YYYY", 0, tp.file.title, "YYYY-MM-DD")%>|A<%tp.date.now("YYYY", 0, tp.file.title, "YYYY-MM-DD")%>]]**
## Rituals & Routines
>[!important]- Last Week
>![[<% tp.date.weekday("YYYY-[W]WW", -7, tp.file.title, "YYYY-[W]WW") %>#What I would like to do next]]
- !!!col
	- ###### 🌱 Plant
		- [ ] Review calendar
		- [ ] Set objectives
		- [ ] Schedule tasks
	- ###### ✨ Weekly Rituals
		- [ ] 🏠 Project check-in
		- [ ] ➕ Therapy/Journal
		- [ ] 💠 Budget review
		- [ ] 🍃 Meditation
	- ###### 🪴 Grow
		- [ ] Review diaries
		- [ ] Learning log
		- [ ] Migrate or cancel incompletes
## Recap
```dataview
table without ID
	file.link AS "Date",
	day-no AS "📆",
	weight AS "#️⃣",
	exercise AS "🏋️",
	mood AS "🫥",
	symptoms AS "📋"
FROM "The Library/The Study/Diary/<% tp.date.now("YYYY",0, tp.file.title, "YYYY-MM-DD")%>"
WHERE file.name = "<% tp.date.weekday("YYYY-MM-DD", 0, tp.file.title, "YYYY-[W]WW") %>"
	OR file.name = "<% tp.date.weekday("YYYY-MM-DD", 1, tp.file.title, "YYYY-[W]WW") %>"
	OR file.name = "<% tp.date.weekday("YYYY-MM-DD", 2, tp.file.title, "YYYY-[W]WW") %>"
	OR file.name = "<% tp.date.weekday("YYYY-MM-DD", 3, tp.file.title, "YYYY-[W]WW") %>"
	OR file.name = "<% tp.date.weekday("YYYY-MM-DD", 4, tp.file.title, "YYYY-[W]WW") %>"
	OR file.name = "<% tp.date.weekday("YYYY-MM-DD", 5, tp.file.title, "YYYY-[W]WW") %>"
	OR file.name = "<% tp.date.weekday("YYYY-MM-DD", 6, tp.file.title, "YYYY-[W]WW") %>"
SORT file.name ASC
<% tp.date.weekday(“dddd, MMMM Do”, 0, tp.file.title, “YYYY-[W]WW”) %>
![[<% tp.date.weekday(“YYYY-MM-DD”, 0, tp.file.title, “YYYY-[W]WW”) %>#Diary]]
<% tp.date.weekday(“dddd, MMMM Do”, 1, tp.file.title, “YYYY-[W]WW”) %>
![[<% tp.date.weekday(“YYYY-MM-DD”, 1, tp.file.title, “YYYY-[W]WW”) %>#Diary]]
<% tp.date.weekday(“dddd, MMMM Do”, 2, tp.file.title, “YYYY-[W]WW”) %>
![[<% tp.date.weekday(“YYYY-MM-DD”, 2, tp.file.title, “YYYY-[W]WW”) %>#Diary]]
<% tp.date.weekday(“dddd, MMMM Do”, 3, tp.file.title, “YYYY-[W]WW”) %>
![[<% tp.date.weekday(“YYYY-MM-DD”, 3, tp.file.title, “YYYY-[W]WW”) %>#Diary]]
<% tp.date.weekday(“dddd, MMMM Do”, 4, tp.file.title, “YYYY-[W]WW”) %>
![[<% tp.date.weekday(“YYYY-MM-DD”, 4, tp.file.title, “YYYY-[W]WW”) %>#Diary]]
<% tp.date.weekday(“dddd, MMMM Do”, 5, tp.file.title, “YYYY-[W]WW”) %>
![[<% tp.date.weekday(“YYYY-MM-DD”, 5, tp.file.title, “YYYY-[W]WW”) %>#Diary]]
<% tp.date.weekday(“dddd, MMMM Do”, 6, tp.file.title, “YYYY-[W]WW”) %>
![[<% tp.date.weekday(“YYYY-MM-DD”, 6, tp.file.title, “YYYY-[W]WW”) %>#Diary]]
Can anyone help me understand what's gone wrong?
Thank you in advance!
In the Dataview query with the FROM line you’ve changed to tp.file.title,"YYYY-MM-DD". This is most likely the cause of your problem.
Ah, there were a few instances of those and correcting them did fix the issue! Thank you so much for pointing that out!
