Templater - prompt for properties and filename
Create a new note which prompts for few properties and use couple of this properties for file title.
In properties the prompt method works as expected, for e.g.
<% await tp.system.prompt("Day?") %>
When trying to use on of this properties to set file name, it fails
<% tp.file.rename(tp.frontmatter.topic) %>
Tried different combination and found frontmatter does not have the value yet.
There are many posts about setting properties or renaming a file, but couldn’t find anything which talks about both.
Thanks in advance.
