Templater not working what's wrong?
Hi!
I am currently testing templater.
If I use the default template Introduction | Templater
but it doesn’t work
creation date: <% tp.file.creation_date() %>
modification date: <% tp.file.last_modified_date("dddd Do MMMM YYYY HH:mm:ss") %>
<< [[<% tp.date.now("YYYY-MM-DD", -1) %>]] | [[<% tp.date.now("YYYY-MM-DD", 1) %>]] >>
# <% tp.file.title %>
<% tp.web.daily_quote() %>
When I insert the template, nothing change, i get the template file with all the code
But usual template like {{Title}} works fine.
Is there any option that i miss out ?
The hotkey for templater is not the same as usual template …
