Templater not rendering in view mode
Just trying to use Templater
A simple command is not rendering in view mode… it just shows the text
File content: <% tp.file.content %>
Templater is installed in the workspace
The following posts may be of help. The first is for the core Templates plugin, but the process is the same. One way to trigger Templater is the command: Templater: Open Insert Template modal and choosing the template you made with the Templater code in it.
