I have this bad habit of expecting something to work the way I think it should work and get lost when it doesn’t. I’ve spent hours trying to make this happen and need help. Maybe it just can’t be done.
I have created a template called “core properties”. In this template, I’ve added the minimum properties that I want in all my notes. I intend to include the core properties in each of my more specific templates, like a books template. I expect that when I apply the books template to a new note I will get the core + book properties. I’ll add examples below.
This generally works. Where I run into problems is when a property name in the specific template matches a property name in the core.
In the core I have:
tags:
Every file needs a tags property in my vault. If I’m creating a new generic note this ensures there’s a tags property.
In the book template I have:
tags: book
This kills it. When I apply the book template to a new note it silently fails. No output.
I’ve tried everything I can think of. I’ve concluded it’s probably working as designed. But, I’m more of an Obsidian user than a troubleshooter. It doesn’t seem like what I’m asking is far fetched. I’m hoping I’m just missing something simple.
This is what’s in my core template:
tags:
note_status: inbox
note_type:
hub:
context:
created: <% tp.file.creation_date(“YYYY-MM-DD HH:mm:ss”) %>
modified: <% tp.file.last_modified_date(“YYYY-MM-DD HH:mm:ss”) %>
And this is what’s in my test template that works:
<% tp.file.include(“[[Core Properties]]”) %>
testTag: newTag
And this fails silently:
tags: newTag
Any help? It doesn’t need to be templater. Is there another option? Or am I just thinking wrong about this whole template thing.
Kev
