I’m trying to include a section in my daily notes for tasks due on or before the date of the note.
I can do it easily enough like this for today:
tasks
not done
due before 2022-07-01
However, I have to manually change the date to the day after the daily note to catch everything.
Is there a way to say:
“due before the date of this daily note + 1”
That way, it can just be an automatic part of my template instead of me needing to tweak it each time.
Thanks!
Absolutely! How you write this will depend a little on which plugins you use and how the “date of this daily note” is stored.
Here’s an example for Templater plugin and the daily note filename being “YYYY-MM-DD”.
due before <% tp.date.now("YYYY-MM-DD", +1, tp.file.title) %>
Here’s an example if you use Periodic Notes, Calendar, or another one of @liam 's plugins:
due before {{date+1d}}
Do these help? If not, what do you use for your templates and how is the “date of this daily note” kept track of?
Thanks for that! I appreciate your help.
system
Closed
#5
