Hello!
I’ve using Obsidian for a while now and I have settled on some workflow that I’d like to automate a little from now onwards.
I usually have a lot of Projects that I need to keep track of and most also relate to programming, so I’ve found that working with Kanban boards is the optimal setup for me.
I have a “Projects Kanban” with “Projects” Tasks that link to each “Project Kanban”.
Then, each “Project Kanban” has a set of tasks with a link to the corresponding file that might be a “Project Task Kanban” or any other file.
Currently this has been working very well for me, but I have to do everything by hand.
When creating a Project:
1.- Create the “[[Project Task]]” task in the “Projects Kanban”
2.- Click the link “[[Project Task]]” to create the file
3.- Import my Kanban Template in to the new file
4.- Move the file to a sub-folder where the “Project Tasks Kanban” are located (This is a sub-folder in the same directory)
When Creating a Project’s Task:
1.- Create the “[[Task]]” task in the corresponding “Project Kanban”
2.- Click the link “[[Task]]” to create the file
3.- Import my Kanban Template (or another template) in to the new file
4.- Move the file to a sub-folder in the same directory (Here I’d like it to be a folder for each “Project”)
So I’m trying to implement that workflow in an automated manner. Meaning that:
A. I’d like to be able to provide a “Project Name” and it creates a task in the “Projects Kanban” and a Kanban Board from my Template in the corresponding “Projects Folder”, then opens it
B. When inside any “Project Kanban”, I’d like to be able to provide a name that creates a task in the “Project Kanban”, creates the file from a selection of templates in the particular “Project Tasks Folder” and opens it
I’ve read many things on-line, tried implementing it with QuickAdd, tried the Projects Plugin, and some other things, but I haven’t been able to suceed, particularly with the files/folder managing aspect, and I’m not even sure what would be the best approach to accomplish my goals.
Considerations
- I’m using Metadata Menu and I’d like the implementation to not break it
