ckpiv
1
Not sure when this began but I believe after the last update v1.2.0 Installer v1.1.9.
The Tag Pane only sorts when showing nested tags but only sorts the second level nested tags. The main parent tags do not sort?
I have tried this on different vaults and using default theme and get the same results, no sorting of parent tags.
Has anyone else seen this behavior and or am I missing something here?
PR-C
2
Can replicate. This post should probably be moved to bugs.
Fixed?
Continuing the discussion from Obsidian Release v1.2.1 (Insider build):
ckpiv
4
Yes the Insider build v1.2.1 has fixed the issue
system
Closed
5
