HI. I have noticed that when renaming a tag that appears in the front matter of some notes, Obsidian will modify the instances of the tag being renamed until it runs into a tag in a front matter and then give an error and stop the process. If I go manually rename the instances of this tag that exist in front matters and try batch renaming the tag again, everything now runs as intended.
I’m not sure if this is a limitation of tag wrangler plugin or of front matters ?
