Clicking on the tabs in the application no longer works reliably. After some time, the tabs no longer respond to clicks, the corresponding view does not open. As a (poor) workaround, it helps to move the tabs, which then opens the window. All tabs are affected, center as well as left and right pane.
I haven’t experienced this. Can you give more detailed steps to reproduce? Like “click 5 tabs” or “wait 5 minutes” or whatever you can identify.
I wasn’t able to reproduce in the sandbox vault (same MacOS and Obsidian versions as you). I opened the sandbox vault and clicked back and forth among the default left sidebar tabs for 50 clicks, then opened a new tab in the main area and clicked back and forth between that and the existing note for 50 clicks.
Hi! I have a similar issue: after searching notes by tag, I can’t go back to the Tags panel. Only double-clicking works all the time. Tabs don’t work well for me either.
The problem might occur because of an external screen. There is no problem when I use the main screen of my Mac.
Everyone in this thread, if you could, please provide your “Show Debug Info”.
And if you are on an older installation version, try reinstalling from the latest 1.5.3 download on the website. And make sure you give it a test in the Sandbox vault to make sure it isn’t a plugin or CSS snippet that is causing the issue. (kl_s, I see you did already, but that was an older post and an older version. I wonder if you’re still experiencing this.)
I can’t reproduce this either. It’s working fine on my side.
Obsidian version: v1.5.3
Installer version: v1.5.3
Operating system: Darwin Kernel Version 23.2.0: Wed Nov 15 21:53:34 PST 2023; root:xnu-10002.61.3~2/RELEASE_ARM64_T8103 23.2.0
Snippets enabled: 1
Plugins installed: 17
Plugins enabled: 17
1: Kanban v1.5.3
2: Better footnote v1.0.1
3: Vocabulary View v0.1.2
4: Calendar v1.5.10
5: Periodic Notes v0.0.17
6: Mind Map v1.1.0
7: Reading Time v1.1.1
8: Obsidian Functionplot v1.2.1
9: TimeStamper v1.3.0
10: Fleeting Notes Sync v0.6.3
11: Obsidian Git v2.22.1
12: Templater v2.1.2
13: Latex Environments v0.4.2
14: Dataview v0.5.64
15: Excalidraw v2.0.18
16: Quick Latex for Obsidian v2.6.4
17: Projects v1.17.1
I’ve tried to reproduce this bug in the newly created vault – but it doesn’t work. I can also notice that this bug sometimes appears and sometimes does not
I have this problem on my machine as well. I figured out exactly when it happens and found a fix (that works in my case at least). Don’t know the root cause.
Specs
macOS Sonoma 14.4.1
Obsidian Debug Info (to emphasise that this also happens in brand new vaults without any community plugins/themes and snippets):
Obsidian version: v1.5.12
Installer version: v1.3.5
Operating system: Darwin Kernel Version 23.4.0: Fri Mar 15 00:11:05 PDT 2024; root:xnu-10063.101.17~1/RELEASE_X86_64 23.4.0
When it happens / How to reproduce
Use Obsidian…
… in full-screen mode (note: this is not the same as maximised mode on Macs) AND
… on any screen that is not your laptop screen.
To reiterate, this issue only comes up when both conditions (1) and (2) are met.
Fix
I normally use my built-in display (laptop screen) as the main display and my monitor as the extended display.
I switched this around and made my monitor the main display (which automatically makes the in-built one and extended display).
Clicking on tabs is now working as expected on both displays, regardless of whether Obsidian is full-screen or not.
The last version I’m aware of that was required to update manually was 1.4. There was also an important security update a while back. Your first step should be downloading and reinstalling manually.
(This may or may not address this issue for you.)
Otherwise thanks for the details and the clues! I wonder if that was a common factor for the other people.
I don’t think it’s the installer because @demn has the latest minor release but is still facing the same problem. I will update my installer anyway though, it’s been long overdue, you’re right!
